Article ID : 00135843 / Last Modified : 21/10/2020Print
When using the NFC function, which mode should be selected in the camera?
    Touch the mobile device to the camera when the following shooting modes are selected.
    NOTE: The selectable shooting mode differs depending on which camera you use.
    • MOVIE: Movie mode
    • PHOTO: Photo mode
    • INTVL: Interval photo recording mode
    • LOOP: Loop recording mode
    If the camera is still unable to connect, check the following settings on the mobile device:
    • Make sure that the NFC function is turned on and active.
    • Make sure that the Screen lock is turned off or disabled.
    • Make sure that the Sleep mode setting is turned off or disabled.
