Article ID : 00083811 / Last Modified : 27/12/2017
How to proceed if "There is no update file" appears during software update using the USB port?
    To avoid getting the error message when doing a software update, make sure that the update folder is labeled as UPDATE (in all capitals) and that all the files listed below are included inside it.
    • MSBXX-FW.BIN
    • MSBXX-FW.ID
    • MSBXX-FW_MB.BIN
    • MSBXX-FW_MB.ID
    After confirming that all the files are included in the UPDATE folder, you can then download and transfer the files to your USB storage device.
