Article ID : 00149245 / Last Modified : 29/01/2018
Unable to change the TV picture settings when watching a Netflix video
    The Netflix application does not have a Picture setting option. You should  change the picture settings through the TV   menu then go back to watching the desired Netflix video.
    NOTE: The link provided is applicable if you're using a Sony Bravia TV. If using a TV from another manufacturer, please refer to the supplied manual for instructions on how to adjust the picture settings.
