Article ID : 00068294 / Last Modified : 29/03/2019
Which cameras are compatible with the RM-VPR1 remote control?
The RM-VPR1 remote control is provided with both a Multi Terminal and REMOTE Terminal (3-pin) cable so it can be used with cameras that have either of those connections.
Multi Terminal and REMOTE Terminal cables
Compatible camera models are listed below.
DSLR cameras: The DSLR cameras below are compatible using the REMOTE Terminal cable.
  • DSLR-A100
  • DSLR-A200
  • DSLR-A300
  • DSLR-A350
  • DSLR-A500
  • DSLR-A550
  • DSLR-A560
  • DSLR-A580
  • DSLR-A700
  • DSLR-A850
  • DSLR-A900
SLT Cameras: Depending on the model, all SLT cameras are compatible either by connecting the Multi-Terminal or REMOTE Terminal cable.
NEX Cameras: The only NEX camera supported is the NEX-3N using the Multi Terminal cable.
ILCE Cameras: The ILCE models below are compatible using the Multi Terminal cable.
  • ILCE-5000
  • ILCE-7
  • ILCE-7R
Cyber-shot: The Cyber-shot models below are compatible using the Multi-Terminal cable.
  • DSC-RX100M2
  • DSC-RX10
  • DSC-HX50
  • DSC-HX50V
  • DSC-HX300
Video Cameras: The video camera models below are compatible using the Multi-Terminal cable.
  • DEV-50
  • DEV-50V
  • FDR-AX100E
  • HDR-PJ220E
  • HDR-PJ320E
  • HDR-PJ420VE
  • HDR-PJ230
  • HDR-PJ240E
  • HDR-PJ330E
  • HDR-PJ380
  • HDR-PJ430V
  • HDR-PJ530E
  • HDR-PJ650VE
  • HDR-PJ660
  • HDR-PJ790V
  • HDR-PJ810E
  • HDR-CX410VE
  • HDR-CX220E
  • HDR-CX230
  • HDR-CX240E
  • HDR-CX280E
  • HDR-CX290
  • HDR-CX320E
  • HDR-CX380
  • HDR-CX900E
  • HDR-GW66
  • HDR-GW66VE
  • HDR-GWP88
NOTE: The REMOTE Terminal cable can be used to control Minolta and Konica Minolta (Dynax/Maxxum) cameras that have a 3-pin remote release socket.
