Password Error is displayed on the smartphone
This message appears when you enter the wrong password when connecting your camera to a smartphone using a Wi-Fi connection.
Make sure the password is entered correctly - remember, the password is case-sensitive.
If the error message still appears after you've entered the correct password, delete the connection from the smartphone and then re-establish the Wi-Fi connection.
