Article ID : 00092971 / Last Modified : 10/02/2015
How do I change the AF Range Control value?
Follow the instructions below to change the AF Range Control value:
  1. Press the AF RANGE button or C (Custom) button several times until the shooting distance bar displayed on the screen turns orange.
    NOTE: For the ILCA-77M2, the AF Range Control function is assigned to the C (Custom) button in the default setting. Once you have changed the assigned function, the AF Range Control function cannot be operated with the C (Custom) button.
  2. Set the maximum shooting distance using the Front control dial and set the minimum shooting distance using the Rear control dial.
