Article ID : 00162801 / Last Modified : 14/11/2016
Error: aip-70 appears when trying to play a Netflix movie on a Google TV device
    This error may appear when trying to play a Netflix Movie. Follow the steps below to troubleshoot the issue:
    NOTE: Because each of these steps represents a possible solution to this issue, login to Netflix app and try playing a movie after completing each steps.
    1. Deactivate  your Netflix account from your Internet TV device.
    2. Force close the Netflix app:
      1. Press the FN+1 buttons to display the Settings menu.
      2. Press the down arrow button to select Applications.
      3. Press the ENTER button.
      4. Press the down arrow button to select Manage applications.
      5. Press the ENTER button.
      6. Press the down arrow button to select the Netflix app.
      7. Press the ENTER button to select Force stop.
      8. Press the ENTER button to select OK.
      9. Press the down arrow to select Clear data.
      10. Press the ENTER button.
    3. Reboot the Internet TV device .
