Article ID : 00158708 / Last Modified : 16/09/2016
I cannot find applications that I installed in My Apps.
Please verify that the application has been successfully installed by searching for it using the Search for Apps box located on the upper right corner of the Opera TV Store. Once found, check if the Install option on the application detail page is available. If not, it indicates that the application has already been installed. If the Install option is still available, install the application again.
