Article ID : 00162440 / Last Modified : 10/11/2016
Content error message appears when trying to view a Netflix video
    When the Content error message appears, this is an indication that the device requires a software update to play the desired Internet content.
    Sony Internet video devices have one of the following menu settings that will help you avoid errors that are easily fixed with a software update.
    • Set the device to receive automatic updates. When this setting is set to On the device will automatically download updates.
    • Set the update notification setting to On. When this setting is enabled, a notification will appear when a new update is available.
    For model-specific information regarding which of these two settings are available or how to set either of these settings, refer to the supplied operations manual.
