The registration code for the Sony Essentials website does not appear in the menu
A code will not appear if the product was previously registered. To resolve this issue, unregister the product by following the steps below:
- Turn on the TV.
- Using the supplied TV remote control, press the HOME button.
- Scroll to the Network menu.
- From the Network menu or the BRAVIA Internet Video menu, select Unregister.
- Press the Select button.
NOTE: After deregistering the product from the Sony Essentials, you may follow the steps above and select Activate Enhance Feature to register the product.
