Article ID : 00164288 / Last Modified : 29/03/2019
How to disable or enable Internet Protocol Version 6 (IPv6) (Windows 7)
Disabling IPv6 may resolve Wi-Fi and WLAN connection issues, such as dropped or failed connections. Some older WLAN or Wi-Fi routers or access points may not support this protocol.
  1. Click the Start button and then click Control Panel.
  2. In the Control Panel window, click Network and Internet.
  3. In the Network and Internet window, click Network and Sharing Centre.
  4. In the Network and Sharing Centre window, in the left pane, click Change adapter settings. Image
  5. In the Network Connections window, click to select Wireless Network Connection and then on the menu bar, click Change settings of this connection.
    NOTE: If Change settings of this connection is not available, click the right arrow to display it, as shown in the image below:
  6. To disable Ipv6, in the Network Connections Properties window, under This connection uses the following items:, click to uncheck the box next to Internet Protocol Version 6 (TCP/IPv6) and then click the OK button.
    NOTE: To enable IPv6, click to check the box next to Internet Protocol Version 6 (TCP/IPv6) and then click the OK button.
  7. Close the Network Connections window.
