Article ID : 00070888 / Last Modified : 30/03/2021
Error: The image database file is damaged.
    This message appears when the image management files are damaged. By touching YES, you can create new image management files and begin to use the camcorder normally.
    NOTE: For model-specific information regarding how to create or repair image files, refer to the operating instructions supplied with the product.
