Article ID : 00202807 / Last Modified : 27/06/2019
macOS Mojave(10.14) Compatibility Information for Application Software
    IMPORTANT: Operation is not guaranteed for all computers.
    Application SoftwareVersionApplicable Product CategoriesmacOS 10.14
    (Mojave)
    Notes
    Imaging Edge (Remote/Viewer/Edit)
    *64-bit only
    1.3.00Cyber-shot
    α (Alpha)
    Under Evaluation
    PlayMemories Home3.6.01Handycam
    Cyber-shot
    α (Alpha)
    Action Cam
    Bloggie / Webbie
    Digital Recording Binoculars
    Under EvaluationWe have confirmed that some functions cannot be used when using this app on a PC upgraded to MacOS 10.14. We are currently reviewing the situation to come up with a solution.
    Image Data Converter
    Handycam
    Cyber-shot
    α (Alpha)
    Not Support
    Downloading of Image Data Converter has been discontinued since September 2018.
    Please use Imaging Edge (Remote/Viewer/Edit) from now on.
    Remote Camera Control-Cyber-shot
    α (Alpha)
    Not SupportDownloading of Remote Camera Control has been discontinued since September 2018.
    Action Cam Movie Creator3.6.01Action CamUnder EvaluationWe have confirmed that some functions cannot be used when using this app on a PC upgraded to MacOS 10.14. We are currently reviewing the situation to come up with a solution.
    MVR Studio1.0.03 or laterMusic Video RecorderCompatible
    IPTC Metadata Preset1.1.00α9 (ILCE-9)Under Evaluation
    PlayMemories Camera Apps-Cyber-shot
    α (Alpha)
    Compatible
