Shooting tips > Capture Dynamic Landscapes
LESSON 3Capture Dynamic Landscapes
Focal length: 16 mm / F-number: 11 / Shutter speed: 1/100 sec
If you encounter an extensive landscape while traveling, you want to capture it in a photograph just as it is, including its magnificence and the brisk atmosphere you feel at the moment.
To take photographs like these, set the camera to the A-mode and try the techniques below.
Shooting with smaller apertures
First of all, use smaller apertures to shoot landscapes. Setting the aperture value to around F8 brings the entire image sharply into focus, although the recommended value may vary depending on shooting conditions or lenses.
Generally, if you want to take sharp photographs with high contrast, increase the F-number. Conversely, if you want to add a soft feel to the entire image, decrease the F-number.
Shot with the aperture set to F9.0, this photograph looks sharp, with both the pine in front and the sky in the background in focus. If the F-number is too small, the photograph tends to suffer from the lack of crispness, as only either the tree or the sky can be in focus.
Focal length: 16 mm / F-number: 9.0 / Shutter speed: 1/30 sec
Capturing the wide range on the wide-angle side
If you shoot landscapes with a zoom lens, you can capture the wide range of the scene by using the wide-angle side (with shorter focal lengths) of the lens. Also, if you shoot landscapes that include the sky, filling a large area of the image with the sky will give a more extensive impression and convey the power of the scene.
This photograph was shot on the wide-angle side of the zoom lens. Although the main subject is the ocean, the magnificent atmosphere is enhanced by filling a larger area with the sky and clouds, instead of capturing only the ocean in the entire frame.
Focal length: 16 mm / F-number: 11 / Shutter speed: 1/800 sec
How to enhance sharpness and vividness
If you want to render the landscape or clouds more sharply and vividly, change the Creative Style settings. Selecting the [Landscape] setting will enhance contrast and saturation, and finish up the photograph with enhanced image depth. If you want additional contrast in colors or shadows for a more impressive finish, adjust "Saturation" and "Contrast" in the option settings. Each parameter can be fine-tuned with ± 3 steps.
[1] Creative Style: Standard[2] Creative Style: Landscape
Saturation: +2 Contrast: +2
These photographs were shot with different Creative Style settings. Photograph [1] was shot with [Standard]. Photograph [2], meanwhile, was shot with [Landscape] with "Saturation" and "Contrast" enhanced in the option settings. As a result, the sky and colored leaves are reproduced vividly and powerfully.
However, take care not to enhance contrast and saturation too much. This may result in a photograph that looks like a painted picture because of color saturation.
Trying wide-angle lenses
To shoot dynamic photographs with a wider angle of view, using wide-angle lenses is recommended.
Wide-angle lenses can capture a wider range of scenes than human eyes. As a result, you can enjoy capturing unique images in everyday snapshots and street shots, as well as landscape photography.
Focal length: 11 mm / F-number: 10 / Shutter speed: 1/80 sec
SAL1118
This lens offers a range of focal lengths that are indispensable for serious indoor and architectural photography, as well as any other situation that demands wide-angle coverage.
It features ED glass and aspherical elements that reduce flare and aberrations to a minimum, for crisp, high-contrast images even under difficult conditions.
Focal length: 10 mm / F-number: 11 / Shutter speed: 2.5 sec
SEL1018
This ultra wide-angle 10-18 mm zoom lens is ideal for expansive landscapes, as well as emphasized perspective with any subject.
Aspherical and ED glass elements in a precision optical design contribute to spectacular resolution and contrast right out to the image edges.
With a constant maximum aperture of F4 through the entire focal length range, you can take advantage of the bright aperture to utilize fast shutter speeds even in low light.
