Article ID : 00226510 / Last Modified : 27/06/2019
Use Memory and Memory Recall on a Camera
Use Memory and Memory Recall to save and load your frequently used settings on your camera.
What Settings Can You Save?
  • Shooting Mode
  • Aperture and/or shutter speed
  • Settings in theCamera Icon tab (There are some options that cannot be saved.)
Save Your Settings to Memory
  1. Select a shooting mode such as M, S, A, P, Auto, SCN, S&Q, Panorama (Panorama), or Movie(Movie).
  2. Set up your camera with the settings you want to save.
  3. Press the MENU button.
  4. On the Camera Icontab, select Memory.
  5. Press the left and right buttons to select your save location.
    • 1, 2, or 3 for your camera's internal memory.
    • M1, M2, M3, or M4 for the memory card.
  6. Press the center button.
Recall Your Saved Settings
Follow the steps depending on the location where you saved your settings:
  • 1, 2, or 3
    1. Turn the mode dial to either MR, 1, 2, or 3.
      • The modes on your camera vary depending on your model. Check your manual for model-specific information.
        • ILCE-6000
          Alpha 6000
        • ILCE-7
          Alpha 7 Mode Dial
        • ILCE-9
          Alpha 9 Mode Dial
      • If your camera has MR mode, press the left or right button to select 1 or 2.
    2. Press the center button.
  • M1, M2, M3, or M4
    2. Press the left or right buttons to highlight your saved location.
      Memory Card Save
    3. Press the center button.
Other Information
  • You can select Memory Recall or Recall from the menu to switch between settings in the memory card and the mode dial.
    • Memory Recall or Recall is only active (not grayed out) if the mode dial is on MR, 1, 2, or 3.
  • If you select Memory Recall or Recall, you can inspect the saved settings. To see all the settings, press the down button.
    Settings
  • Saved settings remain in memory even after you perform Camera Settings Reset.
  • Selecting Initialize deletes settings in 1, 2, and 3.
  • Formatting the memory card deletes settings in M1, M2, M3, and M4. You won't access the saved settings if you remove or replace the memory card.
