Article ID : 00068294 / Last Modified : 29/03/2019
Which cameras are compatible with the RM-VPR1 remote control?
    The RM-VPR1 remote control is provided with both a Multi Terminal and REMOTE Terminal (3-pin) cable so it can be used with cameras that have either of those connections.
    Multi Terminal and REMOTE Terminal cables
    Compatible camera models are listed below.
    DSLR cameras: The DSLR cameras below are compatible using the REMOTE Terminal cable.
    • DSLR-A100
    • DSLR-A200
    • DSLR-A300
    • DSLR-A350
    • DSLR-A500
    • DSLR-A550
    • DSLR-A560
    • DSLR-A580
    • DSLR-A700
    • DSLR-A850
    • DSLR-A900
    SLT Cameras: Depending on the model, all SLT cameras are compatible either by connecting the Multi-Terminal or REMOTE Terminal cable.
    NEX Cameras: The only NEX camera supported is the NEX-3N using the Multi Terminal cable.
    ILCE Cameras: The ILCE models below are compatible using the Multi Terminal cable.
    • ILCE-5000
    • ILCE-7
    • ILCE-7R
    Cyber-shot: The Cyber-shot models below are compatible using the Multi-Terminal cable.
    • DSC-RX100M2
    • DSC-RX10
    • DSC-HX50
    • DSC-HX50V
    • DSC-HX300
    Video Cameras: The video camera models below are compatible using the Multi-Terminal cable.
    • DEV-50
    • DEV-50V
    • FDR-AX100E
    • HDR-PJ220E
    • HDR-PJ320E
    • HDR-PJ420VE
    • HDR-PJ230
    • HDR-PJ240E
    • HDR-PJ330E
    • HDR-PJ380
    • HDR-PJ430V
    • HDR-PJ530E
    • HDR-PJ650VE
    • HDR-PJ660
    • HDR-PJ790V
    • HDR-PJ810E
    • HDR-CX410VE
    • HDR-CX220E
    • HDR-CX230
    • HDR-CX240E
    • HDR-CX280E
    • HDR-CX290
    • HDR-CX320E
    • HDR-CX380
    • HDR-CX900E
    • HDR-GW66
    • HDR-GW66VE
    • HDR-GWP88
    NOTE: The REMOTE Terminal cable can be used to control Minolta and Konica Minolta (Dynax/Maxxum) cameras that have a 3-pin remote release socket.
