Skip navigation
Currently Being Moderated
VGN-AR51J cant set up drivers for Gforce 8400m GT(Windows 7)
Topic started on Jul 24, 2012 3:05 PM , last reply on Aug 4, 2012 1:28 AM
in VAIO and Computing > Notebooks
menoumenou 4 posts since
Jul 24, 2012
hello there i write this post beacuse i cant install any version of driver of my card (Gforce 8400M GT) since i set up the Windows 7 in my laptop (Sony vaio VGN-AR51J).
Please i have stuck with the default drivers that cant give me the all the benefits that i have pay for these....e.x HDMI CONNECTION WITH A TV.....
please please help me i want to solve this immidiatly.......
  • rich912 9,306 posts since
    Aug 28, 2004
    Written on Jul 25, 2012 10:25 AM
    Hi menoumenou,
    The problem could be that you have installed Win 7 64 bit and the only Sony released drivers are 32Bit (Vista). Some Vista drivers will work with Win 7 but 32Bit and 64Bit are not compatible.
    To install a non Sony released driver you will need to use a modified INF file. Have a look at the following links for more information.
    http://forums.laptopvideo2go.com/topic/9243-forceware-updaters-quickstart-guide/
    http://laptopvideo2go.com/drivers
    http://laptopvideo2go.com/enhancer
    Rich
    Go n-éirí an bóthar leat
    • Reply
  • bribonne1 3 posts since
    Feb 11, 2011
    Written on Jul 27, 2012 8:40 PM
    Hi Rich,
                I didn't see any reply as to 32 or 64 bit on menoumeanou;s laptop? If it is 32 bit then it is a straight forward download and the Vista driver should work.
    However if he has a 64 bit system it is a nightmare as Nvidia do not support any Sony laptop and reccomend download from Sony and again there is no 64bit support for the Geforce 8400M graphics card!!.I had this problem but I did eventually succeed in getting a driver to run on my VGN-AR61M laptop,and this how I did it.
    1.Download free driver sweeper and analyse you system.( I used 'Driver Fusion')
    2.Remove all traces of any Nvidia drivers from your system
    3.Download Mobility Modder (Free driver modder.Make sure you get the Nvidia version.
    4.Download the driver for your card from Nvidia.(I used 296.10 64bit for win.7 @Vista.
    5.Run the download so it loads into a Folder on your hard drive.(mine was under my C drive Nvidia)
    this attempt will likely fail!! Don't despair.
    6.Now open the Modder programe and browse to C/Nvidia and open the driver file,then run the Modder programe.It will add or remove several file and stop.
    At this point you can try running the driver again you may be lucky.(I wasn't!!)
    7. Now the stroke of genius I looked at the PCI/VEN in my 32 bit driver on my vista 32bit system.(Ihave a dual system on my laptop) I noted down the PCI/VEN Numbers.I then opened the 64 bit windows 7 sytem and browsed to the downloaded and now modded Nvidia driver  file.I opened the folder and opened it until I found the driver file.I opened that and then opened the RAR file it opens in notepad.I went down the file until I found the lines PCI/VEN with several numbers in each line.I beleve there were five lines.I went through each line ammending it to read the same as my 32 bit driver.In mycasethey were as follows.
    1) PCI/VEN_10DE&DEV0426'SUBSY_9016104DeREV__A1
    2)PCI/VEN_10DE&DEV_0426&SUBSY_9016104D
    3)PCI/VEN_10DE&DEV_0426&CC_030000
    4)PCI/VEN_10DE&DEV_0426_0300
    I DELETED THE LAST LINE.AND THE RAN THE DRIVER FROM C/NVIDIA SETUP.It loaded and ran perfectly I now have Nvidia control panel and PhysX in control panel.
    I hope this helps some people I know 1st hand how frustrating this problem is.
    Bribonne1
    • Reply
    Feb 11, 2011
    Written on Aug 4, 2012 12:31 AM
    Hi menoumenou,
                               sorry I do not use skype.I will try to make it easier for you.If you are useing 32bit Windows go to the Sony support site and download the Nvidia driver from the Vista update section in your models support/download page.
    If you are useing 64bit then there is no support for the Nvidia graphics card, so you must try to download one from Nvidia and in my case the one they recommend does not load up.It gives an error report CANNOT FIND COMPATIBLE GRAPHICS DEVICE.! iF THAT IS YOUR PROBLEM YOU MUST MODIFY THE DRIVER.I downloaded 296.10 and modified the NVAR FILE .
    1. Go to Nvidia driver download and save the file to your downloads folder.
    2. Go to Start / Computer/C/user/downloads
    3.Find the downloaded driver double click and it will load into your hard drive.
    4.It will most likely not load and give the error CANNOT FIND COMPATIBLE GRAPHICS DEVICE.
    5.Close all open folders.
    6.Go to Start/Computer.Click to open C drive (Or whichever is your operating drive.)
    7.At this point you may see a folder called Nvidia if not open your programes folder and scroll through until you locate Nvidia.
    8.Open the folder it should say Winvista 64.
    9.Open that folder it should say 296.10
    10. Open that folder and you should see IS.
    11.Open that folder and you should see a long list of folders.
    12. Open the first folder Display you should see another long list of folders.
    13 Scroll through the folder until you find NVRAR
    14.Open NVRAR it should open in notepad.
    15.Scroll through until you see a list of lines like those in my first reply i.e PCI/VEN --------------
    16.Replace those lines with those in my first reply above.
    17. Close the programe.
    18.Go to C/ Nvidia and run the driver setup file.
    19. It should now load the driver and you will have Phsyx and Nvidia in control panel.
    Hope that helps Bribonne1
    • Reply
Share
