Skip navigation
Currently Being Moderated
Hard disc problem message from windows
Topic started on Jun 10, 2012 8:21 PM , last reply on Jun 11, 2012 10:20 AM
in VAIO and Computing > All-in-one Desktops
Drosophilia 3 posts since
Jun 10, 2012
I have a VPCL13S1E that keeps getting a message from windows that there is a hard drive problem and back up before it fails  ST31000528S ATA device. I have run the hard disc diagnostic from viao care for both local disc C and memory, both of which say there is no problems.
So I am now don't know if there is or is not anything wrong with the hard drive or not. Can anyone help with this.
  • binbash 60 posts since
    Jun 1, 2012
    Written on Jun 10, 2012 9:30 PM
    Hi Drosophilia
    You can try to run the windows checking tool on the disk itself.
    You can go to My Computer, right click on the Local Drive C and click on Properties, a new window will pop up, select the Tools tab from this and then run the Error-checking .
    Hopefully that will pick up something.
    Keep us posted
    • Reply
  • rich912 9,306 posts since
    Aug 28, 2004
    Written on Jun 11, 2012 10:16 AM
    Hi Drosophilia,
    I would not ignore this SMART warning.
    SMART detects both mechanical and electronic component problems. Error checking on the disk surface will not detect these problems.
    Either backup all your data or make a mirror image of the drive while these functions are available to you. Usually it is not a case of ‘if’ but ‘when’ the drive fails...
    Rich
    Go n-éirí an bóthar leat
    • Reply
Share
