Skip navigation
Currently Being Moderated
Sony VAIO VGN-FW21L Start up problem
Topic started on May 16, 2012 5:23 PM , last reply on May 16, 2012 11:45 PM
in VAIO and Computing > Notebooks
1 posts since
May 16, 2012
I am having continual problems when starting up my laptop.
It started off periodically refusing to start up, only solution was to disconnect poer lead, remove battery then try again.
I was then asked to reboot and repair etc etc.
Anyone help?
  • Blencogo 12,798 posts since
    Dec 22, 2004
    Written on May 16, 2012 11:45 PM
    Hi ronhood4 and welcome.
    Unfortunately it could be many things to include both hardware and software faults.
    What exactly happens when you try to start up?  Are there any sounds/lights or is it completely dead?
    I presume you are still using Vista?
    Firstly, I would start with software and try running the 'Startup Repair' by tapping F8 during bootup and choosing 'Repair my Computer' -> 'Startup Repair'.
    I would then try to repair any corrupt system files by using the System File Checker by going to the command prompt and running "SFC /scannow.
    Next, try running a Registry cleaner to remove debris accumulated over time.  Your Vaio may be searching for links to software that has been uninstalled or removed.
    If those fail try checking your hard drive using Vista's error checking: -
    http://windows.microsoft.com/en-us/windows-vista/check-your-hard-disk-for-errors
    Next ..... start looking at hardware problems.
    • Reply
Share
