Skip navigation
Currently Being Moderated
VAIO VGN-FS115Z HDD Upgrade
Topic started on May 14, 2012 2:39 PM , last reply on May 14, 2012 5:42 PM
in VAIO and Computing > Notebooks
2 posts since
May 14, 2012
Hi
I have a 2005 model with a 100GB ATA-6 HDD. Does anyone know whether it is possible to replace this drive with a SATA device please?
sgoodch
Message was edited by: sgoodch
  • Blencogo 12,799 posts since
    Dec 22, 2004
    Written on May 14, 2012 5:20 PM
    Hi sgoodch and welcome.
    I don't think this is possible with a laptop computer.  There is just not enough space to add an IDE to SATA converter to a new SATA drive and then to get it back into the limited space inside the laptop case.
    You would also have to find SATA Controller and several drivers that may not be available.
    Your Intel 915PM Chipset does support SATA but I think you will need to replace the drive with another ATA hard drive - this is not a problem as PATA drives are available.  If this had been a desktop computer with plenty of space, then it may have been possible.
    • Reply
Share
