Skip navigation
Currently Being Moderated
The tablet won't start
Topic started on May 1, 2012 8:40 PM , last reply on May 2, 2012 2:56 PM
in Sony Tablet
2 posts since
May 1, 2012
Hello,
I have recieved the Sony Tablet S two days ago, and today I have tried to switch it on but it is not working. I have plugged the tablet (because I thought the battery was dead) but it's still won't start. Please let me know what to do.
Many thanks.
  • Written on May 1, 2012 9:08 PM
    Hi AlisonJudith,
    welcome to Questions & Answers..
    A friend of mine had a similar problem a couple of days ago & after charging the tablet started as normal..
    However if charging does not help & your Tablet still does not turn on try the following..
    Press the power button.
    If the tablet still doesn't start, press the reset button carefully with an opened paper clip
    If after doing a reset your Tablet still fails to turn on then a repair may be necessary. Please contact support
  • Written on May 2, 2012 2:56 PM
    AlisonJudith wrote:
    Hello,
    Thank you for your reply, I did what you said and it perfectly worked
    Excellent, you're welcome..
    As to connecting to your router are you selecting from the list of available networks.?
    Are you sure you are entering the correct wireless password don't forget that the password is case sensative..
    Altenatively does your router have WPS if so have you tried connecting using the WPS push button option.?
Share
