I have a SVRHDT-500 Recorder. When I set the recorder to record something after I've gone to bed or go out, it doesn't record as the TV is switched off. The recorder automatically switches itself off when I turn the TV off, which really defeats the object of a recorder as you generally record things when you are away from home!!
I have tried changing the Standby Mode and doing a factory reset on the recorder but nothing has worked. I have had two or three hard disk recorders and this has never been a problem. I would like the recorder to stay on when the TV is off. Can anyone help please?
Message was edited by: Meddie47
Message was edited by: Meddie47 UPDATE 15.4.2012: All OK now. I had another go at going through all the functions via the menu and found if I changed the HDMI control to "Off", the box stays switched on when TV is off. Allelujia!!!
