Skip navigation
Currently Being Moderated
Possible Bug?
Topic started on Mar 7, 2012 10:20 PM , last reply on Mar 7, 2012 5:48 PM
in Sony Tablet
11 posts since
Feb 24, 2012
Good evening.
I've got a problem with the tablet.
The model is:
SGPT113PT
Android Version:
3.2.1 (relaease2)
compilation:
THMAS0142400
It is the following:
When the screen turns off
(It was programmed to shut down after 15 minutes).
Or even if I press the button to turn off the screen, the tablet will not turn on  ...
(it happen 4 times  in 1 month).
I have to press for a while the "Power" button or use a clip to press the "Reset" to reconnect the tablet.
The tablet then connects normally after that.
Doesn't show any anomaly, any error, nothing ..
Operates everything right ...
(Now i  increased the time to 30 minutes just in case).
At the 1st time it happened I did a:
"Replacement Data Factory"
I thought it might be a conflict with some program installed, although I have almost nothing installed from the market ...
But however it happened again ..
I think it is a bug, since the tablet does not present any anomaly while working ...
But I could be wrong ...
Is it bug or hardware problem...
Best regards.
  • 161 posts since
    Feb 15, 2012
    Written on Mar 6, 2012 1:01 AM
    I have seen this issue in the past but for different models. Have you tried updating the display adapter drivers? https://imagicon.info/cat/12-13/vmware_happy.gif
    • Reply
  • Watashiwateshdes 413 posts since
    Feb 24, 2011
    Written on Mar 6, 2012 5:25 PM
    If you wiped the Tablet itself and ensured you are on the latest software, I cannot see there being much else that can be done to resolve this. From what you have mentioned, that would be something which may need to be looked at.
    I have not actually been able to reproduce this on my Tablet so could be a fault. As to what it is causing it, not 100% sure. Have you tried just having the factory install apps on only? It could be due to a specific app which you may have installed.
    See if your supplier is prepared to swap it?
    • Reply
    Feb 24, 2011
    Written on Mar 7, 2012 12:01 PM
    You got to remember, Sony did not have to include any software if they wished but some of them are nice to have like the social media and the music player. Some companies just give you the basic Google build and let you do what you want. I always look at it as better than nothing.
    As for returning it, I would recommend having a word with the Sony sales division or on your email, they may be contact details from when you placed the order or try using the link below.
    http://www.sony.pt/support/pt/contacts/tablet
    Keep us updated on how you get on.
    • Reply
Share
