Skip navigation
  • 4 posts since
    Apr 7, 2012
    Written on Apr 7, 2012 11:15 PM
    Hi Rich,
    Thanks for the above advice.
    My problem is similar to Stevie's. The problem being that I would like to replace the keyboard, but want to buy a cheap non-Vaio one. Is there any way to adjust the brightness without using the "Fn" key of the Vaio keyboard? Normal keyboards don't have that key, I think.
    Also, the menu on the side of the screen of the VGC-LV1S does not seem to do much, as Stevie said. I followed your above steps, but nothing seems to have happened - the menu is still very basic and does not contain brightness controls.
    Will
    • Reply
Share
