Skip navigation
Currently Being Moderated
BDP S570 Clicks & Flashes?
Topic started on Dec 26, 2011 3:31 PM , last reply on Dec 31, 2011 2:19 PM
in TV & Home Cinema > DVD, Blu-Ray & HDD Recorders
2 posts since
Dec 26, 2011
We have just bought a BDP S570.  It is connected to an LG 3100. The problem is that playback is interrupted every few seconds by a momentary flash to a white screen with an accompanying click.  Has anybody had a similar problem and found the solution or has an idea of what might be going on?
  • Bravia55HX923 1,825 posts since
    May 12, 2011
    Written on Dec 26, 2011 3:45 PM
    the BDP-S570 is an excellent machine albeit alittle noisey at times, however clearly yours is not right and i would advise you check carefully once more your player settings and if its no different soarce a replacement as soon as possible.
    • Reply
Share
