As described above, I'm having no joy with the iPlayer on my new S-185 (one of the main reasons I bought it). Using the arrow buttons on the remote to navigate the iPlayer interface results in completely random operation. It simply will not let you select certain menus - you can try, but it will just flicker and select a completely different menu entirely. I simply cannot access any of the services I want.
I think other users have had similar issues with different Sony Blu-Ray models and had success by resetting the hardware to factory setting etc. I have done all this and ensured that I have the most up to date firmware. Still no joy... has anyone got any ideas??
Hi, I have exactly the same problem and it's really frustrating. I like the player a lot but this problem is a real let down, especially as the programs I can access look great especially the iPlayer HD ones.
Someone please help ! I have updated the software and reset as the user above.
Cheers.
Hi, OK I will do this as you advise. It's very strange as other internet services such as Youtube seem to be running fine. Also the areas of iPlayer that I can manage to navigate to work fine. I see that in the US/Canada they have just released a version of firmware ending in ...29.
> just to advise you I have now logged this issue with the support line. Case ref. quoted is 27068869.
Thanks.
Message was edited by: DelUK1
iPlayer is a bit of a unique beast - due to the unique standing of the BBC globally and iPlayers success in the UK, its specially configured for UK devices. You wouldn't believe the amount of engineering work that goes into it on our side.
I'll flag with the guys here also and see if they can reproduce it.
Thanks for raising the call.
Hi There,
I have the same problem, same model.
Did anyone get any help with this? I have the same problem, and it's driving me mad. iPlayer is next to useless, I cannot select anything, using the arrow buttons on the remote selects more than one option and hitting select selects random things. It just doesn't seem to work.
It did work when I first used the player yesterday, but I was then prompted to update the unit and it hasn't worked properly since.
I have reset to factory settings and turned it off and on again afterwards. No joy.
Help!!
CB
Hi
I have just bought this player and a big part of the my decison to buy was for the iplayer function.
On switching the player on I could navigate the iplayer menus but could not actually start any of the programmes. I did a update the network and this connected to the internet and updated the player.
With the update installed I tried to use iplayer again and now I cannot navigate the menus but I can start the highlighted programmes.
Is there a solution to this problem ? It does not look good if you can only use this every now and then.
I have two of these, one bought from Tesco and the other from Amazon. Both units have the same issues with BBC iplayer as others have described - i.e. when I move and select a pink highlighted items in the iplayer menu, I am taken to the wrong item - usually the previous one on the list. Same thing for the programme selection - i.e. scrolling down and then selecting a pink highlighted programme will bring up the previous one. Also, searches are impossible - bringing up the search menu where you highlight letters doesn't work - only random letters are selectable; scrolling skips several in the list for no apparent reason. Same thing for channel selection - i.e. selection box doesn't move predictably over the BBC channel boxes, when one is highlighted (e.g. BBC two) and is selected, I am taken to BBC one. It's maddening and frustrating.
This is an iplayer-specific issue. Menus work fine on all other VOD services (e.g. 5 OD, mubi,etc).
The latest updates have been applied (as of 22/01/2012), and I've tried factory resetting everything after updating; the problem remains. To me this appears to be a flaky firmware issue?
I bought one last Sunday, the unit downloaded the latest firmware and I am seeing the same issues - makes BBC iPlayer largely unusable.
Any news on when a firmware update will be made available for the BDP-S185 ? otherwise I am probably going to return the unit for refund.
Any further news on this? I've had my BDP-S185 for about 6 months, firmware update last week & now iPlayer freezes the entire unit. I have to unplug at the mains just to get it to respond to any buttons both on the remote & the unit itself.
Trying other channels like Sky news seems ok.
