Skip navigation
1 2 3 ... 6 Previous Next
Currently Being Moderated
Cases for the Sony Tablet S
Topic started on Sep 22, 2011 3:10 PM , last reply on Jul 19, 2012 1:36 PM
in Sony Tablet
faithx 3,924 posts since
Feb 24, 2004
Has anyone looked at which case if any, they would get for the S?
Looks like Sony is only doing the one, black leather (not really my colour ).  I've had a quick look around and found quite a few different makes, any thoughts?
This site has quite a few:
http://www.letstalktablets.com/best-cases-and-sleeves-for-your-sony-tablet-s/
  • 7 posts since
    Jan 16, 2008
    Written on Sep 22, 2011 3:30 PM
    I went into the sony shop and seen the tablet case.. ummm
    Lots of money and you have to add stick strips to the back of the tablet to keep it in the case.
    At that point I got a small laptop bag.
    • Reply
  • Blencogo 12,803 posts since
    Dec 22, 2004
    Written on Sep 23, 2011 12:28 AM
    faithx wrote:
    After having a good look around, have decided to go for a nice colourful sleeve, which will fit nicely into my handbag
    Very understated Faith!!
    I'm sure more accessories will become available over time - probably not quite like that one tho'!!!!!!!
    • Reply
  • Watashiwateshdes 413 posts since
    Feb 24, 2011
    Written on Sep 23, 2011 12:37 AM
    I saw those slip cases. I will get around to ordering one, honest! If you get some time, please let me know if it is any good (not to raise any doubts) as atleast something before I throw it into a backpack.
    • Reply
  • 5 posts since
    Sep 18, 2011
    Written on Sep 23, 2011 9:56 AM
    Please Guys .. Don't just go out and buy something that will be a compromise.
    I went to the Tuff Luv outlet yesterday and they will be bringing a case out in 2-3 weeks which will be specially made for the tablet. It will open like a book and have an adjustable support to enable it to be propped up at various angles for viewing.
    Here's a preview .. http://www.gearzap.com/tuff-luv-tri-axis-veggie-leather-sony-tablet-s-case-black.html
    • Reply
  • 5 posts since
    Sep 18, 2011
    Written on Sep 24, 2011 6:44 PM
    There's also a case made by STM called the "skinny"
    It's not out yet but it looks quite good and should come in other colours in addition to black.
    It's also on the gearzap site.
    • Reply
  • 4 posts since
    Sep 23, 2011
    Written on Sep 24, 2011 9:22 PM
    I picked ip one of these from asda for about 10 quid(cheaper instore)
    http://direct.asda.com/Hewlett-Packard-Mini-Blue-Sleeve/000512027,default,pd.html
    It fits pretty snuggly and has pockets for other stuff.
    Only using this till I can get a decent clip cover like the leather one sony do.
    • Reply
  • 5 posts since
    Sep 18, 2011
    Written on Sep 25, 2011 12:57 PM
    The gearzap site link is below. The sides look quite well protected. Hopefully for you they will release it in the various colours but I will defo go for black.
    http://www.gearzap.com/stm-skinny-sony-tablet-s-case-black.html
    • Reply
    Dec 22, 2004
    Written on Sep 25, 2011 7:29 PM
    It looks pretty damn good in the Sony SGPCV1! (Excuse the fingerprints).
    • Reply
    Dec 22, 2004
    Written on Sep 25, 2011 8:48 PM
    Hiya Faith,
    1). It is fairly stable in normal use but you would have to take some care as it is only held in position by the edge of the tablet fitting into the groove in the front cover.  That said, I think it is robust enough to use on a train or plane.
    2). Yes, the front cover folds underneath the tablet so you can hold it as normal.
    3). To ensure a solid connection to the case, you do have to stick two strips of Velcro to the back of the Tablet.  The corresponding strips are part of the case.  I was a bit worried about this at first but I am sure they could be removed with care however, you can use the Tablet out of the case without removing them.  Frankly, the case is designed for full-time use as both cameras and all connections can be used in the case - including the charger and the dock when it is released - so I doubt if I will ever take it out of the case very often.
    The main downside is the cost - even for a top-of-the-range real leather fold-over case it is a bit expensive but I am glad I have bought it, it looks very classy.
    I don't really like screen protectors but as the screen is not glass, I will probably buy the Sony screen protectors when they are released.
    • Reply
Share
