Skip navigation
  • 7 posts since
    Jun 30, 2011
    Written on Aug 29, 2011 7:23 PM
    Yes, stefflod mentioned it in an earlier post but I will quote the User Guide again from page 14: "It is recommended that you do not use your computer with the LCD screen lid fully open for an extended period of time. If you do so, the temperature of the bottom of the unit may rise." The customer service also said to me, that I can't open the lid more than 90 degrees or otherwise the air vent gets blocked too much...
    Although my laptop is back from the reparation shop, it still gets way too hot and too loud. However, my vaio does not crash anymore, but the processor just throttles now. If they have a fix that will reduce the temperature and fan noise then I really want to try that one out too.
    In the end I just have to live with it since I need a laptop now and I don't have time to send it again to the repair shop. My advice is just like ripat86 to avoid the vaio SA. Perhaps go for a macbook pro if you don't need windows and don't need the heavy graphics stuff? My friend has a macbook pro and it has a very good temperature control.
    • Reply
  • 7 posts since
    Aug 28, 2011
    Written on Aug 30, 2011 11:36 AM
    Thank you for replies. I personally do not believe that Sony had made any subtle hardware changes, as this would mean changing production line. I think it was the sales person trying it on to get a sale.
    There is a distinct lack of new posts on this and other forums about heat/fan issues, so I am hoping that something has improved.
    As stated earlier, my CTO SA is on order and should arrive with 2/3 weeks. I will let you guys know how it behaves when it arrives.
    • Reply
  • 1 posts since
    Aug 30, 2011
    Written on Aug 30, 2011 6:16 PM
    I have read somewhere that they released a bios upgrade for Vaios which takes care of the loud fan. Anyone here have any information on that? This seems to be common across some laptop manufacturers. I had an HP before and they adviced to upgrade the bios to fix the loud fan issue as well, which to a great extent did fix the noise.
    This has been mentioned on Youtube reviews of this laptop as well.
    • Reply
  • mkhan_4 1 posts since
    Sep 1, 2011
    Written on Sep 1, 2011 2:33 PM
    it is interesting that they are bringing new versions so quickly.
    Message was edited by: mkhan_4
    • Reply
  • 7 posts since
    Aug 28, 2011
    Written on Sep 1, 2011 2:35 PM
    Hi repat86,
                   Thank you for thr link for updated SA. Unfortunately, for now, I am committed to my customised SA, as I have passed the cancellation period.
    • Reply
  • 1 posts since
    Nov 29, 2011
    Written on Nov 29, 2011 3:14 PM
    Fan noise!!?! Unreal, sometimes I hear it from 2 rooms away while it's supposedly doing nothing!
    I bought a VPCSA in August, while travelling in the USA, as it was a cheaper option than buying one in Switzerland where I live. I had a Vaio VGN-SR19VN previously and at the 3 year mark it was grinding a bit and replacement was due, but it had been a great machine.
    I need a grunty yet portable laptop for my work and my replacement was to be another Sony, or a Samsung Series 9 i7, which I'd read good reports on but in the short time I had to shop I couldn't find a Series 9 i7 but I did find a Sony store and left with the i7 SA.
    All looked like a good proposition at the time, then the noise began, off and on, sometimes under load, sometimes inexplicably, but always like a jet preparing for take off.
    I am a photographer and travel with the laptop, working in airports, offices, press rooms, media events etc, and it's such an embarrasing machine as it attracts the ridicule of many around me. Deservedly too. Every time the jet tubines wind up I cringe. What make matters worse is I am usually surrounded by Mac users who are quick to play the "mine is bigger than yours" game.
    I have had a play with the Processor power management, turning down the maximum processor state to 85%, which does keep the noise down but debilitates performance so it kind of defeats the purpose of owning a performance machine, and I need it to work fast.
    It's interesting to read some of the comments on this thread, that a suggestion would be made not to use the screen past 90 degrees is bizarre. Who actually uses a screen at 90 degrees or less, no one I've ever worked with, and interestingly the screen is another weak point of this computer, viewing angles are dubious for photo editing.
    Sure seems like a design flaw to me, and as others have stated. I have been on the road pretty much non-stop since buying it but am now at home and shall be wandering into the local Sony store to have a word. Sounds to me like they are quick to divert blame, but that tends to be modus operandi for the entire computer world in my experience so we will see if this is any different. Not holding my breath...
    • Reply
  • 1 posts since
    Dec 19, 2011
    Written on Dec 19, 2011 10:48 PM
    Dear all,
    I got mine yesterday delivered to Germany.
    Right from the very start the problem of the fan noise was quite obvious to me. Only in Stamina mode the noise is barely acceptable, but only while writing this text here for example.
    I have to admit that, there are 2 different noises, one which arises from the airflow, which is quite deep and not annoying, but the overlaying second one is quite high and sound like a turbine or a jet nozzle which is varying. and this hissing is really filling a large room. everyone was looking at my desk when I rerun the assessment of the "Windows Experience Index".
    2 Years ago i sent back an ordered F-Serie laptop due to this reason and got an old s serie i5 instead which was good. now i ordered another i7, this time s and i am experiencing the same problem.
    the fact that the screen is partly covering the air exit at the back when opened is such a mistake, that actually needs no further comment. The reference in the manual says it all.
    "Please don't use this car for a longer journeys as it could overheat!" WOULD YOU EVER READ THAT?
    And I hardly can imagine how sony can fix this without exchanging this built-in dragon.
    And another point is the screen itself. you can nearly bend it like a chewing gum. I have the carbon one and that seems very fragile!
    ONE EASY QUESTION AROUSES and I mean that seriously:
    DOES SONY ACTUALLY TEST AND COMPARE THEIR LAPTOPS BEFORE STARTING MASS PRODUCTION?
    This all is inconcievable and inacceptable.
    Frankly spoken: Right back to sony with this "piece of great craftsmanship"!
    • Reply
  • 1 posts since
    Apr 25, 2012
    Written on Apr 25, 2012 7:29 PM
    I bought my SB series laptop only 4 months ago in December but ever since I was annoyed by the extreme loud fan noise and overheating even when i was doing web browsing and basic tasks. eventually 2 months ago i contact vaio repairs and requested them to look in to this issue, so far I  have sent my laptop twice to sony repair and they couldn't manage to fix this issue and I was told that the motherboard and RAM have been replaced. once again I m sending my laptop tomorrow but I doubt it if they come up with a solution. as everyone else has mentioned here this is the design flow. iam just hoping to get my refund and buy cheaper and more reliable laptop from other vendors.
    • Reply
  • Kalafior 2 posts since
    Jun 10, 2012
    Written on Jun 10, 2012 4:48 PM
    I bought my VPCSB last year but had not chance to use it properly until last Christmas when I found out the level of noise (both fan and airflow) is simply unacceptable and I could not focus on work. I also used it (once) in a business presentation and it was such an embarrassing experience seeing my client faces, having difficulty to understand what was being said over loud noise. I contacted Sony support and was quite impressed by how quickly laptop was collected and returned (3 days), only to find out it was not working at all (engineer replaced the fan but forgot to connect SSD). Called Sony again, arranged another collection to be advised that everything is perfectly normal and they can’t hear any noise. Called Sony centre and gave a sample of the noise to the support person. They agreed the laptop was too loud and promised another collection to fix it. Received my laptop few days later with a note everything is perfectly normal and that “Fan noise – to compare please use unit of the same design – all of the SB series behave the same way here”. Contacted Sony support again with request to refund or replace with another model. After being redirected about 10 times between technical support and pre-sales (both claiming they are not the right people to make such decision) I am not sure who I should speak to. I also decided to post my case on the Sony’s website and to make potential buyers aware of the problem. Can Sony please join the conversation and comment on the problem?
    • Reply
    Jun 10, 2012
    Written on Jun 10, 2012 5:31 PM
    I posted a video demonstrating the VPCSB noise
    http://www.youtube.com/watch?v=lr-cW3yATac&feature=youtu.be
    • Reply
Share
