Skip navigation
1 2 3 Previous Next
Currently Being Moderated
New S Series Vaios Overheating?
Topic started on Jul 2, 2011 6:49 PM , last reply on Jun 10, 2012 5:31 PM
in VAIO and Computing > Notebooks
21 posts since
Jun 28, 2011
I just got a CTO SA series Vaio and I find it is heating up very quickly and I worry it may be over heating. I also find the fans seem to be extremely loud which I presume is due to it being very hot.  I did temporarily have a SB Vaio with very similar specification and never had this issues so would it only be specific for the SA?  Has anyone else with a SA Vaio noticed this or is it a known issues? And does anyone know how I can fix it?
Message was edited by: ripatel86
  • 7 posts since
    Jun 30, 2011
    Written on Jun 30, 2011 10:38 PM
    Hi.
    My Vaio VPCSA arrived yesterday and I experience the same problem. When I'm just browsing through the internet the temperature of the cpu cores is around 55-60 C. When I run demanding programs which take up 60% of the cpu, the temperature rises to 95 C and the fan will get extremely loud. I think the hinge of the screen blocks the back vent, because when I close the screen I feel a lot more air coming out the backside.
    I'm also interested if this is a known issue and whether this can be fixed.
    • Reply
  • Blencogo 12,807 posts since
    Dec 22, 2004
    Written on Jul 1, 2011 2:08 AM
    There are relatively few VPCSA-Series Vaios out there yet and to date this is the first I have heard of this on these forums..
    If there is a problem it is important you make sure Sony are aware of it by registering your concerns with Vaio Support giving details and temperatures if possible.
    • Reply
  • 2 posts since
    Jul 1, 2011
    Written on Jul 1, 2011 8:49 PM
    My SA arrived yesterday and I was also struck by hearing the fan mainly on boot-up, which I wasn't used to on my old Dell D630. The SA has an i7 chip so that may be a bit much. The hinge does impede the main vent at the back. I've been working on it all day connected to a monitor with the screen partly closed over so the hinge is not such a blocker and the fan has barely kicked in at all.
    Just found this in the manual:
    It is recommended that you do not use your computer with the LCD screen lid
    fully open for an extended period of time. If you do so, the temperature of the
    bottom of the unit may rise.
    Looks like it is a design fault then but they've put it in the manual so maybe we're supposed to be fore-warned. What is the point of a laptop if you can't use it as a laptop to the extent of its battery life?
    Message was edited by: stefflod
    • Reply
  • 7 posts since
    Jun 30, 2011
    Written on Jul 1, 2011 9:49 PM
    Yes I just found it too in the manual. I contacted Sony by Vaio Support so now I just wait for their reply and I hope they can do something about it. If not I guess I have to return the laptop, because I don't have everywhere I work an extra screen at my disposal. I'll edit my message when I get a response of Sony.
    • Reply
  • 5 posts since
    Jul 5, 2011
    Written on Jul 5, 2011 1:20 AM
    HI all,
    I received my Vaio VPCSA custom spec last week and I'm not happy at all. I have an Intel i7, 8gigs RAM, 128gig SSD, 1gig AMD Graphics.
    I am also experiencing extremely loud fan noise when using the machine for the most basic of things like using Visio or Word. When I use it for gaming (5 year old games) the fan is so loud and high pitch that it simply isn't bearable to play it for long - if I do play for 30mins or so then the games often crash and return to desktop.
    The temperature generated on the underside of the laptop and on the screen hinge is worryingly high. When I connect it to an external monitor, turn off the laptop display and close the lid the fan noise reduces slightly but is still outrageous and even more worryingly the temperature then generated when it is closed from the keyboard and appears to transfer to the laptop screen.
    I think there must be a design flaw with the machine which would be forgivable for a machine worth £300 but this one is £1500 and it took me a long while to save and select the right spec laptop for my needs. So I find the issues completely unacceptable for a top end laptop.
    I have begun communicating with Sony VAIO-Link support team on this matter and i will keep you posted.
    I do hope as a loyal Sony consumer that they can resolve this quickly or refund/replace/recall the machine as after the Playstation 3 fiascos of late including the reduction of functionality without prior warning and some shocking Sony Walkman software which I was forced to use for years ruining an otherwise great product - I might be inclined to jump on board the Microsoft and Samsung ships for good.
    Phil
    Message was edited by: Phil_UK
    • Reply
  • 7 posts since
    Jun 30, 2011
    Written on Jul 5, 2011 10:50 AM
    Hi
    So Sony Vaio Support emailed me. They want to pick my Vaio up for investigation which will take about 5 workdays. They also say I have to remove my battery, which I am a bit scared to do since I'm not that handy and I am affraid to break the warranty or something.
    I guess I have no other choice then just send it back for repair. Luckily in the Netherlands we have a standard warranty of 2 years. So all the costs should be for Sony. Still I am a bit disappointed that such an expensive laptop doesn't work straight away and now I won't have a laptop for a week or more...
    • Reply
  • 5 posts since
    Jul 5, 2011
    Written on Jul 5, 2011 1:12 PM
    I have just got the same response from Sony Vaio Support and they want to collect mine.
    I actually have to go away for a couple of weeks so wont be able to do this immediately but please keep me posted on how they handle your issues. Fingers crossed its merely a manufacturing issue or mistake and not simply that the machines have been over spec'd and are running too hot.
    • Reply
  • 5 posts since
    Jul 5, 2011
    Written on Jul 8, 2011 10:27 AM
    Its normal behaviour for the laptop to sound like a vacum cleaner on your desk? incredible. Well if that is the verdict we all get given then I guess my faith has finally run out in this once fantastic brand. Such a shame.
    • Reply
  • 7 posts since
    Jun 30, 2011
    Written on Jul 8, 2011 6:02 PM
    The support in the Netherlands said that I should just send it to them and never said anything that this is normal behaviour. One of the conditions for sending it for repair was that if there is no problem with it I have to pay the transport costs and diagnostics which is €80. I would have appreciated it if the support notified me that this is 'normal' behaviour.
    This means that I paid almost €1500 to get a vacuum cleaner laptop which gets too hot to play games and pay an extra 80 bucks to verify that my laptop is indeed a hot vacuum cleaner
    My Sony contact person wrote per mail that UPS should pick it up today, but I'm still waiting and they haven't shown up yet. So this time I called Sony instead of emaling and he said that it is possible that it will arrive Monday instead of today..
    I also asked about the cpu temperature and the hinge and he said that 95 C is a normal working temperature and that it's better not to open the screen more than 90 degrees. So Sony indeed regard this as normal behaviour. I still let them check my Vaio SA because I want to be sure that this (high temperature, loud fan, system crash) is the product Sony delivers and that not something malfunctions only in my Vaio.
    Message was edited by: Ray1090
    • Reply
Share
