Skip navigation
Currently Being Moderated
CMTMX750Ni - Streaming from MAC
Topic started on May 13, 2011 2:59 PM , last reply on Mar 11, 2012 2:41 AM
in Audio > Hifi Systems
1 posts since
May 13, 2011
Hello There,
I need advice to assist me in setting up the wifi streaming from my MAC laptop via my Sony CMTMX750Ni.....
Is this possible?
Stevie
  • 1 posts since
    Mar 11, 2012
    Written on Mar 11, 2012 2:41 AM
    Hi, I had to sort this out on my own and so thought I would share it  with you, if you are still looking for a solution to connect your mac to  your SONY.
    You will need to download TVMOBILI from tvmobili.com
    The software will let you stream your mac's content using your home network.
    It is an easy way to stream music to the hifi.
    Hope it helps.
    • Reply
Share
