Skip navigation
1 2 3 Previous Next
Currently Being Moderated
TalkTalk/Tiscali iPlayer issues on Blu-ray
Topic started on Mar 1, 2011 12:17 PM , last reply on Apr 13, 2011 9:37 AM
in TV & Home Cinema > DVD, Blu-Ray & HDD Recorders
8 posts since
Jan 28, 2011
The BBC iPlayer has been given an overhaul. The problem is that the new interface gives a "not enough memory" error - and we're now unable to use the iPlayer.
It's a problem that has also been registered by others at the BBC's iPlayer forum.
Can we rewind to the old interface please ?
Message was edited by: Catmambo
  • 6 posts since
    Nov 26, 2010
    Written on Jan 28, 2011 2:28 PM
    Common problem Mark. See thread here - https://www.sony.co.uk/discussions/thread/112657?tstart=30
    If you are with Virgin as you're ISP, I posted a "workaround" by setting a proxy server on the BBC iPlayer forum - http://www.bbc.co.uk/dna/mbiplayer/NF13735683?thread=7907457
    That lets the "bigscreen" interface load rather than the full website page which crashes as there's not enough memory in the player to handle it.
    I have streaming issues (especially with HD) as do others - https://www.sony.co.uk/discussions/thread/112657?tstart=30
    • Reply
  • 6 posts since
    Nov 24, 2010
    Written on Feb 16, 2011 10:36 AM
    Also with Talk Talk
    Any chance of a fix for this Sony or Beeb?
    • Reply
  • paulgrecothompson 23 posts since
    Feb 3, 2011
    Written on Feb 17, 2011 12:15 PM
    Here is a trimmed down temporary fix I developed on the other thread.. the fix is not as long winded as it used to be..
    1) Turn off your bluray / device
    2) Go to your computer, and go to your broadband's access page.  If it's Tiscali (where most of the problems are) and you have a Thomson router, it will be http://192.168.1.254
    3) Where it says "broadband connection" click "disconnect"
    4) Wait a few secs, then click "connect"
    5) Go back and switch your player back on.  After the player has reconnected to the internet with a new IP address, Iplayer should now work.
    6) If this doesn't work first time, repeat till it does.
    The problem seems to be with certain Tiscali (but not just Tiscali) IP addresses.  It could be working fine for ages - then the network goes down, comes back on, gives you a "bad" IP address, and the problem occurs. Going through this procedure, you may pick up another "bad" address.. keep trying till you get a "good" one.
    Don't hold your breath for Sony to find a solution.  They said on the other thread they see it as Tiscali's problem and will not act - this despite the fact the problem is not replicated by other browsers (PC, Wii) on the same network.  When people like myself lose patience and suggest spreading the word through bad reviews, and taking the problem higher up, posts are deleted and threads are locked.. despite the massive help they give to the problem Sony refuses to face.
    Edit: By the way, it's probably got nothing to do with any BBC "overhaul".  There is a theory changes made around xmas caused buffering problems, but the "not enough memory" problem has been around since October, possibly beyond.
    Message was edited by: paulgrecothompson
    • Reply
  • 8 posts since
    Jan 6, 2011
    Written on Feb 17, 2011 8:57 PM
    I notice that the other thread has been locked........by Sony perhaps, not liking the comments?
    I have had enough now and have put this review on Amazon, with 1 star
    I bought this before Christmas...great delivery as ever, easy to set up, but I do have a Sony TV.......great picure quality when playing Bluray and DVDs. Be aware though, if you use Tiscali/Talk Talk to get your internet, you will not be able to view Iplayer. Sony are blaming the BBC and Tiscali, but it is basically is their fault as their browser doesn't work. I have never got it working yet, hence the 1 star as it is heavily advertised as having this functionality. So if you are getting it for only Bluray...buy it is good,  but if you have Tiscali and want BBC iplayer...avoid like the plague until Sony sort it out.
    That work around has never worked for me unfortunately.....so BBC iPlayer still eludes me!
    • Reply
  • 15 posts since
    Nov 17, 2010
    Written on Feb 18, 2011 1:05 AM
    Hi - I posted the original post. I still have this problem with iplayer - I have a BD570, 732 Sony TV and Tiscali ISP. I am very disappointed that Sony has not helped us with this much, having sold us something with iplayer on the box. Everything else works fine. Paul's workaround has worked for some, and I have have found that sometimes after several iterations round the "not enough memory" loop it suddenly decides to work for no apparent reason. It also tends to work in the mornings but rarely in the evenings. I am still hoping Sony will give us a better workaround, even explain why its happening and maybe give us an update to fix the problem. Other manufacturers of Blu ray players, Wiis etc seem to have coped much better. So, come on Sony, you can do it!
    • Reply
  • specialist-convergence 340 posts since
    Sep 22, 2010
    Written on Feb 18, 2011 2:23 PM
    Hi All
    Just a quick note to say, Sony is still investigating this issue, with the ISP's involved and the BBC.
    Just because the iPlayer works on another device, does not mean the product has a fault, each device has a unique header profile, to tell the BBC what interface to load, the interface is not stored on your player, somewhere outside the control of the player this is going wrong for a very small amount of customers, this is making even more difficult to replicate, however we are doing everything we can to help the ISP's and the BBC to find the cause, when this is identified, we will update all customers who have contacted Sony Customer Information.
    We are sorry there is no new news,  as you can see from paulgrecothomp post above it can be resolved by resetting your routers IP, this should not be required and helps show the issue is not the player.   Please keep an eye out for updates or register you issue and details with Customer Information.   Thank you
    • Reply
  • 8 posts since
    Jan 6, 2011
    Written on Feb 18, 2011 6:56 PM
    We are not suggsting that the individual boxes are faulty, the fact that the other services work prove that not to be the case.
    What we are saying that is that the software in box is inherently flawed we cannot access iPlayer using one of the major ISPs in the country.  I am sure this issue could be fixed by Sony by issuing a new software release that means we can then access the server.  I am also sure that Tiscali or the BBC could also resolve it, but I didn't subscribe to Tiscali to access iPlayer as major reason for the subscription, likewise, the BBC are under no obligation to get it working with your box, but I bought YOUR equipment, to access iPlayer. After all, your packaging comes with with BBC iPlayer emblazed upon the box and is advertised as being accessible. To my knowledge, there was no mention (even in small print) that it warns, incompatible with Tiscali/TalkTalk, though I am happy to be given evidence to the contrary.
    For these reasons, I still feel Sony should be the ones taking the responsibility on this......even if you are on the phone to Tiscali and the BBC hassling them daily to get it resolved, this has gone on for months now.
    Just a quick extra point here, the rerouter setting method has never worked for me, so please don't assume this work around works for all, it doesn't.
    Finally, do have any comment as to why the other thread was locked? I'd be interested to hear the reasons behind it.
    Message was edited by: pawylie29
    • Reply
  • 4 posts since
    Feb 5, 2011
    Written on Feb 20, 2011 5:31 PM
    Hi All,
    My ISP is TelecomPlus (Utility Warehouse) and I have the same problems connecting to the BBC iPlayer as the Tiscali/TalkTalk users. Like the rest of you I am now sick of this issue.
    I installed the latest internet software update on the player yesterday in the hope that it would incorporate a fix, but no joy. I still get the “not enough memory” error message. Surely, after so many months of this problem being known about, Sony should have come up with a solution by now.
    And if Sony are having such a problem replicating the fault at their own offices then they are more than welcome to come round to my house and see it for themselves.
    I bought my Blu-ray player primarily for the BBC iPlayer function as I don't possess any Blu-ray discs and I already have a decent DVD player. The BDP-S370 was marketed as being able to access the iPlayer and no exceptions or qualifications were listed in the advertising or on the box.
    It is not fit for purpose, I'm sorry to say.
    • Reply
    Feb 3, 2011
    Written on Feb 21, 2011 4:42 PM
    "Sony is still investigating this issue" is certainly more encouraging than Catmambo's "This isn't a solution that can be driven from Sony side I'm afraid."  I'm assuming Sony wouldn't carry out an investigation if there were no chance of that investigation driving a solution.
    "Just because the iPlayer works on another device, does not mean the product has a fault.."
    Your setting up a straw man, then knocking him down with a big stick.  Nobody said the device was at fault.  We're saying the software can be changed to avoid the problem - which we know to be the case because other software in other devices is avoiding the problem.  Can I make this any clearer?
    "as you can see from paulgrecothomp post above it can be resolved by  resetting your routers IP, this should not be required and helps show  the issue is not the player"
    No, wrong, it shows that the Sony player has an issue communicating with some of Tiscalis IP addresses.  The issue can therefore be resolved by changing how the Sony player communicates with Tiscali.  One assumes this can be done by altering the Sony software or possibly altering something at Tiscali's end.  But please don't insult our intelligence by saying it proves it's "not the player".  It does no such thing, and even if you could perform the impressive feat of proving this negative, it still wouldn't prove nothing can be done at your end.  Which it can.
    • Reply
    Sep 22, 2010
    Written on Feb 23, 2011 6:05 PM
    Hi All
    I think a few things are being miss understood here, The player does not hold any software for iPlayer, it has a link to a service, to which it will download the data supplied by the provider, this request is carried in the form of a header, to identify its product type and the interface it should be supplied, unlike a PC or games console which has software, this header is being modified during the routing to the supply and returns as a PC, this causes the player to fall over and display out of memory. The difficult facts with this problem is the amount of customers being effected, so far reported to Customer information there are only 44 customer, mostly Talk Talk who have this problem.  Our product quality department are speaking with Talk Talk and the BBC to help them identify what is happening, but as we can’t reproduce the issue here with colleges who are on Talk Talk (including me) it makes it even harder.   The Virgin Media issue is resolved by adding a proxy to the web cache, however this does not help with other ISP's.
    We do have customer with the problem, who have tried alternative providers and the problem is no longer present, we are not able to point any fingers at this time as to why, but every effort is being done to push this matter, however it will take time, however we are working on the problem, even if it is not directly the product at fault.
    As difficult as it is to be patient, we thank for your patience to date.
    • Reply
  • 3 posts since
    Feb 24, 2011
    Written on Feb 24, 2011 1:33 PM
    Quite right! The iPlayer worked fine on the Sony player initially, but rarely does it fire-up now.
    I've placed and enquiry with the BBC, but I'm not expecting much back.
    I don't really want to return my player because it's really good at playing DVD's. On the other hand, I did buy this model because it said it could access the iPlayer.
    By the way, I'm also with Talk Talk.
    It's very disappointing.
    • Reply
  • 1 posts since
    Feb 22, 2011
    Written on Feb 25, 2011 12:06 AM
    I also have the "not enough memory" problem. I bought thr blu ray player last november and it worked finr up until about three weeks ago. At first it was intermittant but for the last two weeks it has not worked at all. I am with Utility Wharehouse who I think use Talk Talk as thier isp.
    Like many the reason for buying this model was the ability to wath i player on the big tv, not any longer. Its very frustrating. I have tried the changing the isp addresss thing, for 40 minutes but to no avail. I dont understand the technicalities of who's problem it is or isnt but would just like to be able to use the player for one of the main reasons it was purchased.
    Cheers,
              Dave
    • Reply
Share
