Skip navigation
  • skipton01 15 posts since
    Jan 3, 2012
    Written on Jan 7, 2012 7:09 PM
    More digging - seen this teardown of a Bravia set and the label is very informative:
    http://www.fullhd.gr/2008-03-14-21-37-34/teardown/7547-sony-bravia-kdl-46ex720-teardown.html
    DBEF stands for dual-brightness enhancement film and it basically sits in the panel to reflect light that's polarised one way, but pass light polarised another.
    I believe that it's this film that we can see when the screens fail and that the failure is due to the film touching another layer in the panel.
    Still researching!
    Jan 3, 2012
    Written on Jan 7, 2012 7:27 PM
    Still researching!
    I think this pdf document from a commercial repairer of LCD panels seals the cause:
    http://www.febalcdrepair.com/UserFiles/file/febalcdrepair.pdf
    The relevant part is the last paragraph of the first section "Polarizer Film Replacement"
  • 1 posts since
    Jan 10, 2012
    Written on Jan 10, 2012 4:01 PM
    I have a Sony KDL46V3000  which has developed exactly the same problems as you describe. It is only 2.5 years old and cost me over £1100 so is a bit dissapointing to say the least. From what I read on the blog here it seems little point in raising the iossue with Sony customer services. I will send them a letter with all the details and let you know how I get on.
    From a technical point of view does anyone know why these dark shadows are happening. is it a reduction in the output of the LCD panel in this area? Is there possibly any form of reset, or perhaps forcing teh screen to output maximum light levels for a period of time that might reset theses dark areas?
  • virginreco 14 posts since
    Jan 5, 2012
    Written on Jan 10, 2012 5:27 PM
    Hello colinmabey
    Read skipton01's posts, he has a background in this sort of thing.
    Jan 3, 2012
    Written on Jan 10, 2012 6:33 PM
    The dark lines are caused by defects in the polarising layer in front of the backlight.  Whether it's heat or manufacturing issues, or both, the result is the same.  Setting the screen to max brightness will have no effect - once the lines and stains become visible, they will only get worse.
  • Jay2203 8 posts since
    Dec 28, 2011
    Written on Jan 11, 2012 11:48 AM
    Noticed a few of you are contacting Watchdog...has anyone got the link? Many thanks.
    As I said in a previous post, neither Sony nor Comet are interested and in fact Sony have stated that they know of know issue of this kind with this TV?!!!!
    Well done Skipton on your research!
    Jan 5, 2012
    Written on Jan 11, 2012 2:32 PM
    Not sure there is a direct dedicated link.
    http://www.bbc.co.uk/watchdog/gotastory/
  • 1 posts since
    Jan 11, 2012
    Written on Jan 11, 2012 10:45 PM
    Just found this thread and thought I was on my own with this fault.
    Can't believe how many others are affected.
    Noticed the dark band on the r h edge of the screen a while ago, but it 's def getting worse (and other vertical 'streaks').
    Can't imagine I'll get any joy from Sony, but that won't stop me trying.
    Also having probs with S380 BD player (fortunately, it's only a month or so old, and bought from Argos), so that's going back.
    Won't be buying another TV set from Sony.
  • 1 posts since
    Jan 3, 2012
    Written on Jan 12, 2012 1:28 PM
    Please add us to the list of people who bought Sony KDL40V3000, had it since dec 2007 like a lot of people first noticed a mark aprox two years ago.Have always bought Sony but will not do again!
    Jan 3, 2012
    Written on Jan 13, 2012 11:49 PM
    OK, so the day for my engineer visit came and went - the engineer never turned up, as apparently their van broke down!  So, that's a days leave to add on to the list of inconveniences.
    In frustration, I phoned the SOny customer helpline and got nowhere - they recommended that I take it in to where I bought it - they couldn't understand that the Sony Centre had closed down - that's Cairo call centres for you.
    I got back in touch with the support/repair centre again and managed to find out that all Sony service centres had recently had a note to say that all Sonex warranties were being transferred to Sony ones (as goodwill only) and I got the number for the Sonex Extended Warranty Helpline (PM me if you want it).
    The number gets you through to Sony, not Sonex and the lady I spoke to there was incredibly helpful - replying to emails promptly and courteously.  All I had to do was scan and email my original shop receipts and warranty card (even though I registered the warranty online) to her and once she had proof of the purchase, her last email said:
    "Thanks, I should be able to arrange a repair for you now"
    So, fingers crossed, I'll have my duff tv collected next week and inspected, then we'll come to some settlement.  I've already broached the subject of replacement as opposed to repair and indicated that I'd rather be able to pay a little more to get a non-S-LCD panelled unit (for those not aware, pretty much all Sony & Samsung televisions since around 2005 have used LCD panels made by a company called S-LCD Corporation, which is a joint Samsung/Sony enterprise, but has recently been taken over completely by Samsung).  The higher end Sony units use Sharp panels (HX and NX series screens), and I'd prefer to get one of these.
    More details later on.
  • 1 posts since
    Jan 17, 2012
    Written on Jan 17, 2012 8:22 PM
    I have exactly the same problem mate,ive had my set is 3.5 and i just had sony visit me to test the set incase of overheating as the sets have been recalled as some were found to overheat so sony came out and tested that component for nothing,while he was here i showed him the shadows and he said i had 4 stain marks on the panel.I am now going to email sony and if i dont get a reply i will be phoning them.I will let u knoe how i get on.
    Jan 3, 2012
    Written on Jan 20, 2012 10:54 PM
    Engineer finally called today - didn't ask to see the issue with the dark lines as he said he was familiar with them, but I demonstrated the problem anyway.
    He agreed that it was a panel fault "seen loads of them - yours isn't too bad, but it'll only get worse.  Loads of Sony's affected and not just the cheaper ones too" he said and took the tv away.  This re-inforces that the issue is the same as those affecting the W and X series.
    He couldn't say if the panel would be available, but he doubted it would be.  I should know what's been resolved by the end of the week.
    So, looks like I'll be bartering with Sony over the replacement model.
  • 1 posts since
    Jan 24, 2012
    Written on Jan 24, 2012 8:39 AM
    Add another one to the list of people with this fault. Had it for a couple of years, but assumed that as it was out of warranty, it was just one of those things. Didn't realise so many sets were affected!
    Jan 3, 2012
    Written on Jan 27, 2012 6:06 PM
    Phoned the menders today, as advised, and I was surprised to hear that they're waiting on a new screen panel, which is expected next week!
    It was my understanding that a new panel would make for a too expensive repair, as it's normally cheaper to just get a new complete television.
    However, I'm not arguing, as the KDL-40V3000 is a decent unit still and I'm not interested in 3D
  • 1 posts since
    Jan 29, 2012
    Written on Jan 29, 2012 12:07 PM
    Add me to the list! It started with a single line shadow 2 years ago on KDL 40V3000 and the tv is 4 yrs old.I thought it was from the sky sports logo but recently more shadows have appeared. I am gutted because this means I am now going to have to replace as I am well out of warranty.One things for sure- it wont be a sony.
Share
