Skip navigation
  • 5 posts since
    Feb 15, 2011
    Written on Feb 15, 2011 9:33 PM
    Yet another with the problem, seems only to affect iPlayer on my BDP370.
    ISP: Be usually connected at 7mb
    Firmware: M03.R.695
    iplayer thru laptop unaffected. Copper between BDP and Router.
    Used to work fine a couple of months ago, now unusable.
  • NorthMonkey 10 posts since
    Feb 16, 2011
    Written on Feb 16, 2011 9:55 AM
    It might be worth checking out if ISP's have introduced a proxy server.  I had trouble with my S370 with Virgin Broadband but set up the proxy as per the IPlayer support pages and now it works fine.
    I still get the odd stall here and there (mostly at busy times) but for the most part I've not had any trouble with IPlayer or indeed any of the other content.  I run a hardwired connection.
  • 6 posts since
    Feb 14, 2011
    Written on Feb 16, 2011 9:57 AM
    I can guarantee that Zen do not run a proxy server or any other traffic shaping or filtering.
    Let's just say I have insider knowledge and leave it at that...
  • 5 posts since
    Feb 15, 2011
    Written on Feb 16, 2011 10:29 AM
    Be was certainly sold on the premise they did no traffic shaping.
    After finding this thread last night, I successfully watched the same programme the BDP had failed on, via my Sony Bravia KDL-40EX403, which is hooked directly into the same router as the BDP.
    This seems like a FW issue if you ask me, far as I can tell, it's just not buffering sufficiently during playback.
  • 6 posts since
    Jan 25, 2011
    Written on Feb 16, 2011 10:48 AM
    I've had this problem and been contributing to this thread since the start of the new year.
    With O2 8meg couldn't watch anything iPlayer on my BDPS370 (SD or HD) for more than ten or fifteen minutes before constant buffering would make the programme unwatchable. As with other posters iPlayer on PC was fine.
    On Monday I had BT Infinity installed (40meg). Last night I was able to watch a whole one hour HD stream and a half hour SD stream on the S370 perfectly with no stalls or buffering.
    Admittedly this was just one night and I may see the problem return, but when you read through this thread and see the majority of people with this problem seem to be on the O2/Be network it makes you think.
    Maybe just the extra bandwidth from the Infinity product masks the problem although it's still there?
    Is it possible some type of proxying or shaping O2 are doing is conflicting with something on the S370? Maybe something to do with LLU providers?
    Will post back in the next few days if the problem re-surfaces with BT.
  • 1 posts since
    Feb 16, 2011
    Written on Feb 16, 2011 5:09 PM
    +1 on this problem with the S570. Our problems started around the same time as other complaints here. We use Be broadband, but the variety of ISPs suggests to me that it's not really an ISP issue. We certainly should have enough bandwidth available, and we've tested at various times during the day (so it's unlikely to be traffic shaping, which Be suggest they don't do).
    I asked Sony's support, and I got this unfortunate response:
    Having looked into this for you, I can confirm that there are no known issues with this model.  Such issues would be documented within the support section of our website.
    I recommend performing the latest firmware update for your Blu-ray player to verify if this resolves the issue.  The latest firmware version for your model can be found at the below web address:
    http://support.sony-europe.com/tvhc/downloads/downloads.aspx?site=odw_en_GB&f=BDPS470_570_v752&v=v2&m=BDP-S570
    If the issue persists, this may indicate that your home network may not have the bandwidth to stream HD High Definition, therefore, I recommend using SD Standard Definition.
    Further to this, I recommend lowering the quality, which can either be adjusted within the BBC iPlayer's own Settings menu, or by choosing the quality at the beginning of the programme you are about to view.
    I trust that this information is useful to you.
    In short, it wasn't useful at all.
  • 8 posts since
    Feb 6, 2011
    Written on Feb 17, 2011 12:00 AM
    I don't think it's a bandwidth problem as, like a couple of other posters here, I have a sony Bravia KDL 37ex 503 internet TV which is connected to the same router as my S370.
    The TV plays I-player perfectly but the S370 buffers every 10 mins.
  • 5 posts since
    Feb 15, 2011
    Written on Feb 17, 2011 12:50 AM
    Given Sony's reluctance to acknowledge this thread, maybe it's time to start getting proactive. Tweeting at @SonyInternetTV is a good start, maybe we can shame them into pulling the finger out.
  • 7 posts since
    Dec 28, 2010
    Written on Feb 17, 2011 9:20 AM
    I updated to .742 a few days ago and sat down last night to watch "The Chinese are coming" pt 1 in HD.
    Flawless.
    Of course this is a one off, so need to see a lot more first. I do note I've seen no issues with the current internet connection for iplayer from PCs or Samsung -- ever (only had it a month). The connections is approx 31 Mbps down, 8 Mbps up measured data speeds (inc. peak)
    So far too early to tell - I had issues before..
  • 2 posts since
    Feb 15, 2011
    Written on Feb 17, 2011 4:21 PM
    I have just upgraded to latest version, as per previously post "UPDATA_M03R742"
    and SURPRISE the fault remains. Top Gear stalled at 17mins and 46 secs.
    Unable too start again.
    Yippee.  NOT!
  • 1 posts since
    Feb 18, 2011
    Written on Feb 18, 2011 7:40 PM
    I'll just add to the list...
    My BDP-S370 is connected by wire to Virgin 10Mb/s cable broadband.
    I get buffering problems which can start any time after about 10 mins of playback.
    Firmware is the latest firmware from the auto update feature.
    Seems to be exactly the same issue that everyone else is reporting.
    The problem started around Christmas - before that all was fine.
    Sony - you're hiding from this one.  Please talk to us!
  • 1 posts since
    Feb 19, 2011
    Written on Feb 19, 2011 8:21 AM
    It's interesting Top Gear has been mentioned a couple of times. I have never had any issues with iplayer on the BDP-S370 until last night. It's not that it was buffering but just that it would freeze after every 10 to 15 minutes with no way out but to go back to Home. It has only happened with this last episode of top gear. I have watched the previous 3 episodes of this series fine. I think it may have happened once during an episode of Outcasts which I also watched this week. The issue with Top Gear was after I had done the new update. I'm on BT and have 4.5mb connection via an ethernet and can usually watch BBCHD without any problems.
  • 2 posts since
    Feb 3, 2011
    Written on Feb 19, 2011 11:36 AM
    I did the firmware upgrade on the 16th Feb to my BDP-S370. (By creating a disc, rather than a network upgrade). And so far I haven't had any more buffering issues on iPlayer (Both SD & HD).
  • 5 posts since
    Feb 15, 2011
    Written on Feb 19, 2011 11:49 AM
    My BDP upgraded itself last night, but I haven't yet had a chance to test iPlayer. I'll post back when I do.
  • 3 posts since
    Feb 19, 2011
    Written on Feb 20, 2011 10:16 AM
    Same problem here.  BBC iplayer does not work anymore.
    1. Decent broadband connection.
    2. Ethernet connection to BDP-S570
    3. Latest firmware
    4. It used to work perfectly and now it doesn't.  Iplayer plays fine for about 5 minutes and then stalls and buffers every 30 seconds or so.
    5. Works perfectly on all my PC's, so it's not the broadband or my network, is it!
    I am 100% convinced this is down to the BBC iplayer changes made a few weeks ago.  It is the BBC's fault, I am sure.  But we need Sony to talk to the Beeb so the 2 companies can fix it between them.
    As it stands, I have a Sony device that is unfit for the purpose for which it was sold.  It is 3 months old, but nevertheless, I will be returning it for a full refund unless this gets fixed.  I already own a BDP-S350 I was quite happy with.
    I only bought the 570 for the iplayer facility, and as it stands, IT DOES NOT WORK.  Sony, please can you do something?
Share
